We’ve got the 2Channel Vibration Sensor which have already worked out-of-the-box with our IOT Edge.
But I have to configure the sensors sample rates. For those I’ve installed the latest Alpha 1.0.2.14 since it was my first Setup with NCD. I configured the COM connection to our MegaModem. Works fine so far.
I triggered the reset on the 2ChanVib Sensor to force a transmit and it was shown in the list, but just as “Unknown Data Source”. As the Doc says : I’ve to use the latest Alpha. But mentioned above, I’ve already the latest.
So, no problem, I’ve found this and tried to configure the sensor with node-red. It looks great! Not was connected/running and seems that it got the update. But since then… I’ve never seen the 2ChanVib again.
Factory Reset is not possible or better : It did not make any changes. Try to configure from MegaModem even also did not work since it didn’t show my sensor.
In Node-Red if you double click on the Gateway Node you will find a check box that says “Output data from unknown devices”. Check that box. You will see this creates a second connection on the Wireless Gateway Node. Attach a debug node to that and also attach a debug node to the first output, then power up the sensor. Let me know if you see anything at all in the two debug nodes.
no, in the beginning I’ve received already some sensor_data. Then I’ve found this video NCD Enterprise Sensor Configuration through Node-Red - YouTube and tried to configure the sensors settings with node-red. It looks great! Not was connected/running and seems that it got the update. But since then… I’ve never seen the 2ChanVib or any sensor packages again. The problems starts with/after the config with node-red
Yes. The switch is in the position of the photo, and totally to the other side to use it by batterie
In the meantime I received a USB-serial part from NCD to flash the Two Channel Vib-sensor.
And re-flashing works great.
Now I want to connect to our company Azure portal with my NCD Edge computer.
Do you have may be a working node-red flow with the Azure connection node and the Two-Channel-Vib-sensor? In particular the way how the “Properties” and “Telemetry” info has to be handled into the node-red Azure node. I can’t find it on the website and/or Github for the Two-Channel-Vib sensor node.
