tomcon
1
what is the pin layout of the molex connector by the “Wireless 2 Channel Vibration Temperature Sensor”?
Need to know where GND/TX/RX/3.3 is to prepare our USB - UART Connector to prepare a reset firmware update
I can’t find anything by the resources on https://store.ncd.io/product/2-channel-vibration-sensor-v3/
Tom
Tagging @Bhaskar in here.
Hi Tom,
from L to R
1-- NC
2 – GND
3 - Tx
4 – 3.3V
5 – RX
tomcon
4
@Bhaskar which Firmware do I really need for the “2 Channel Vibration Sensor Plus”.
I think the sensor is V3, but there I only find a pr55-61n_v4.zip
And is this documentation also for the “2 Channel Vibration Sensor Plus”?
At least the part how to put it into bootloader mode? Because I think it did not work
correct it did not go into bootloader mode.
also make sure Tx and Rx are cross wired.
tomcon
6
Woohooo! That was the trick! Thanks Bhaskar!
