We are having issue with constant the operation of the unit. The sensor is not transmitting data.
The unit is connected to a llot Enterprise gateway. We have configured the unit and connected it to the gateway using Nod-Red. The gateway appears to be functioning properly with a green “Ready” indicator. The sensor appears to be running as indicated by a green “Running” message.
Both gate and sensors are connected to the “debug” tag for trouble shooting.
The gateway sends msg on a regular interval. However, the sensor does not send any data, although it is configured to send data every 5 min. The sensor had appeared to work properly when it was first connected to the gateway, but it stopped sending messages after an hour or so.
Would appreciate your feedback on how we can get the sensor work properly. Thank you.
