I finished the tutorial on how to use NCD’s enterprise sensors with Ignition SCADA software via MQTT. I’ve also posted this on the Ignition forum as well. Enjoy!
MQTT_SensorTutorial_V2.pdf (3.4 MB)
@tbackus
EDIT: Fixed a couple of typos I missed in the pdf first go around.
Hi Daniel,
This is great! Thank you so much for sharing. Would you mind if we formatted the attached PDF into a post for our learn site? We would, of course, name you right at the top giving you credit for the documentation.
Yessir, you are welcome to
Hi Daniel,
I was going to open your link to the ignition forum so we could pull full size images for the post but it looks like the link above does not work. Do you have an alternate link to your forum post over there?
Never mind. I found you post over there which points to this post
I fixed the link to the Inductive Automation forum. I thought I tested all the links yesterday, but I guess not.
