I would like to know if vibration sensor V3 (with FFT and velocity) is supported by the node-red library. Also, is it supported by the Labview Utility ?
Thanks in advance
Thanks in advance
Hi Bert,
No we do not have labview for this sensor.
If the Labview utility does not work with this sensor, how do you configure it? With Alpha Station?
I will recommend node red. This sensor has quite a few user settings. with alpha station only basic settings like duration, node id etc can be configured.
i uploaded the node red flow here
Thank you Baskhar,
We will give this flow a try
Have a nice day
