Yes!
[{“id”:“68541cb3.c2fb64”,“type”:“tab”,“label”:“Flow 1”,“disabled”:false,“info”:""},{“id”:“cd13ed0c.f5536”,“type”:“ncd-wireless-node”,“z”:“68541cb3.c2fb64”,“name”:“3ph”,“connection”:“837142ce.132b28”,“config_comm”:“837142ce.132b28”,“addr”:“00:13:A2:00:41:D5:EF:43”,“sensor_type”:“28”,“auto_config”:true,“node_id”:0,“delay”:300,“destination”:“0000FFFF”,“power”:4,“retries”:10,“pan_id”:“7FFF”,“change_enabled”:"",“change_pr”:“0”,“change_interval”:“0”,“cm_calibration”:“60.6”,“bp_altitude”:“0”,“bp_pressure”:“0”,“bp_temp_prec”:“0”,“bp_press_prec”:“0”,“amgt_accel”:“0”,“amgt_mag”:“0”,“amgt_gyro”:“0”,“impact_accel”:“0”,“impact_data_rate”:“4”,“impact_threshold”:25,“impact_duration”:1,“activ_interr_x”:1,“activ_interr_y”:2,“activ_interr_z”:4,“activ_interr_op”:8,“force_calibration_co2_auto_config”:"",“force_calibration_co2”:400,“filtering”:0,“data_rate”:5,“time_series”:0,“reading_type”:1,“output_data_rate_101”:0,“sampling_duration_101”:1,“x_axis_101”:"",“y_axis_101”:"",“z_axis_101”:"",“sampling_interval_101”:1,“full_scale_range_101”:1,“x”:90,“y”:120,“wires”:[[“e33ea6e5.049788”]]},{“id”:“baa5c3f3.6c8dd”,“type”:“debug”,“z”:“68541cb3.c2fb64”,“name”:"",“active”:false,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“payload”,“x”:590,“y”:180,“wires”:[]},{“id”:“62fdde2d.3785”,“type”:“debug”,“z”:“68541cb3.c2fb64”,“name”:"",“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“true”,“x”:390,“y”:60,“wires”:[]},{“id”:“e33ea6e5.049788”,“type”:“function”,“z”:“68541cb3.c2fb64”,“name”:“function”,“func”:“var label1 = msg.topic;\nvar value1 = msg.payload.channel_1;\nvar value2 = msg.payload.channel_2;\nvar value3 = msg.payload.channel_3;\n\nmsg.payload = {\n [label1]: value1 , value2 , value3\n};\n\n\nmsg.payload.ubidotsDeviceLabel = “3PH”;\n\nreturn msg;”,“outputs”:1,“noerr”:0,“x”:400,“y”:120,“wires”:[[“baa5c3f3.6c8dd”]]},{“id”:“ba03ad81.235”,“type”:“ncd-gateway-node”,“z”:“68541cb3.c2fb64”,“name”:"",“connection”:“9d9ada87.3c6b08”,“unknown_devices”:false,“outputs”:1,“x”:110,“y”:60,“wires”:[[“62fdde2d.3785”]]},{“id”:“837142ce.132b28”,“type”:“ncd-gateway-config”,“z”:"",“name”:"",“comm_type”:“serial”,“ip_address”:"",“tcp_port”:“2101”,“port”:"/dev/ttyS1",“baudRate”:“115200”,“pan_id”:“7FFF”,“rssi”:false},{“id”:“9d9ada87.3c6b08”,“type”:“ncd-gateway-config”,“z”:"",“name”:“Module”,“comm_type”:“serial”,“ip_address”:"",“tcp_port”:“2101”,“port”:"/dev/ttyS1",“baudRate”:“115200”,“pan_id”:“7FFF”,“rssi”:false}]
This flow show me when I turn on the 3 phases current meter, but no de PR55-34
Grettings.
