I have configured the following node-red configuration:
the current node version of the edge-computer is this:
Will there be a problem updating the node version to the latest version? (18.13.0)
Roi
Roi
Hi Roi,
You cannot update Node-Red to v18. The latest it supports is V12.
You can update Node-Red by issuing the following commands in the terminal:
opkg update
opkg upgrade onion-node-red
Hi thank you,
I meant the node.js version, not the Node-RED.
Because when I run
node -v
the output is v8.10.0
so, can I upgrade it to v18?
If only v12 is supported, how to upgrade it to v12?
Roi
