I’m trying to configure my MQTT Gateway to communicate with a PR52-33N. In the MQTT Gateway console I’m receiving the following error.
[{“problem”:“Failed to fetch device settings”,“message”:{“message”:“Failed to parse JSON”,“err”:{“line”:247,“column”:50,“sourceURL”:“http://captive.apple.com/main.js"},“data”:{“type”:"IOT Gateway”,“model”:7,“buzzer”:0,“ssid”:[{“ssid”:“clam”,“rssi”:-52,“encryption_type”:true,“bssid”:“14:91:82:A5:0D:D1”,“channel”:6,“selected”:true},{“ssid”:“clam”,“rssi”:-56,“encryption_type”:true,“bssid”:“58:EF:68:3A:2A:ED”,“channel”:11,“selected”:true},{“ssid”:“clam”,“rssi”:-69,“encryption_type”:true,“bssid”:“14:91:82:A4:FF:79”,“channel”:3,“selected”:true},{“ssid”:“clam”,“rssi”:-74,“encryption_type”:true,“bssid”:“14:91:82:A5:0C:45”,“channel”:9,“selected”:true}],“ssid_password”:“SET”,“interval”:5000,“azure_enabled”:1,“http_enabled”:false,“serial_print_enabled”:false,“apPass”:“SET”,“apSSID”:“WiFi_Micro_Gateway”,“dhcp_enabled”:0,“static_ip”:[192,168,1,11],“default_gateway”:[192,168,1,1],“subnet_mask”:[255,255,255,255],“dns_primary”:[8,8,8,8],“dns_secondary”:[8,8,4,4],“update_available”:false,“update”:false,“update_path”:"",“firmware_version”:“1.0.0”,“mac”:"",“local_ip”:"",“cloud”:{“host”:"",“host_ip”:[x,x,x,x],“host_port”:1883,“tls”:false,“client_id”:“w”,“user_name”:“wwww”,“password”:“SET”,“user_topic_format”:“blank”,“user_gateway_topic_format”:“blank”,“custom_ids”:{},“message_format”:“blank”,“gateway_message_format”:“blank”},“nodeConfig”:false}}}]
Can you provide guidance? Order [#343915] and [#341760]
Kurt
