I have read the PR55-5A manual, but it isn’t clear to me how I can configure it via my Megamodem connected to my MQTT server. I do not have LabView, because it isn’t available for my OS (linux)
The Megamodem is subscribed to the “Megasub” topic, but when I put the PR55-5A into configuration mode by holding down the “C” button for 2 seconds on startup, and send “junk” to the Megasub topic, I don’t even get an error produced.
Do I have to specify every single option? Or is there a way to only specify the option I’d like to change?
Would it be possible for someone to send me a sample MQTT message that would change the frequency which the PR-55A sends data to send more frequently? Every 10 seconds for example.
Here is an example of what my Megamodem is publishing from my sensor on my MQTT server. I’m measuring water level with a 4-20ma sensor.
Megapub {“data”:[126,0,25,144,0,19,162,0,65,244,61,133,255,254,194,127,0,3,3,232,10,0,45,0,27,102,1,226,252]}
