Hi Brian,
The MEMS version supports sending raw values which can be converted into FFT data. The non MEMS version only supports Min, Max, and Average readings for all vibration axis.
If you are going to use Raw Data I highly recommend using the IoT Edge Computer which has more computing power for those requirements. You can take a look at it here:
Also through the IoT Edge Computer running Node-Red you can configure sensor settings so a USB modem is not required.
Is there a document describing how to configure the vibration sensor using the IoT edge computer? I’m looking to zero the sensor, enable time-series data (shown as not implemented in the Node-Red object), and any other sensor configuration.
I just uploaded a video on this topic:
