Wiring 2 wires push button to IoT Long Range Wireless Production Counter Transmitter
Hi guys,
First thing first, I’m new with the product from NCD…
I’d like to know if there’s a way to connect a 2 wires push buttons to the M12 5p connector, like this one:
https://www.google.com/imgres?imgurl=https%3A%2F%2Fwww.circuittest.com%2FMedia%2F400%2Fmb-922.jpg&tbnid=XJy0XlCBMuOLoM&vet=12ahUKEwjz0fP3veP9AhUpEVkFHWmKAi8QMygAegUIARDiAg..i&imgrefurl=https%3A%2F%2Fwww.circuittest.com%2Fmb-922.html&docid=hkrZsf1MhS4mmM&w=400&h=400&q=2%20wire%20push%20button%20switch&ved=2ahUKEwjz0fP3veP9AhUpEVkFHWmKAi8QMygAegUIARDiAg
I’ll there a way to only get a count to test it with this setup?
connect this between white and blue wires of the cable or M12 connector 2 and 3.
Thanks to you for the quick answer. I can now have a count but it seem to be increase by 50.
Is there a way to change that in Alpha Station (for now) ?
i dont think alpha station supports it. You can XCTU to send raw commands.
@jacob can we ad this feature in node red
For now it seems to be the same thing in Node-Red…
Maybe i forgot something, but I don’t really understand the point to get a count only every 50 pulses…
it sends data in two cases
  1. pulses count after a fixed defined threshold
  2. pulses after a fixed defined interval
