Hi, I recently purchased the wireless usb modem and tried to connect it to my raspberry pi and started to get some errors in Node Red. As soon as I assigned the serial port I got kicked out of the server and now when trying to connect I’m getting this error:
6 Feb 18:20:36 - [error] TypeError: “path” is not defined:
at new SerialPort (/home/empiric/.node-red/node_modules/ncd-red-comm/node_modules/@serialport/stream/lib/index.js:116:11)
at NcdSerial.setupSerial (/home/empiric/.node-red/node_modules/ncd-red-comm/lib/NcdSerial.js:28:17)
at Timeout._onTimeout (/home/empiric/.node-red/node_modules/@ncd-io/node-red-enterprise-sensors/wireless.js:54:47)
at listOnTimeout (node:internal/timers:569:17)
at process.processTimers (node:internal/timers:512:7)
I’m trying to further connect a 2 channel 4-20mA receiver to my network.
@Bhaskar or @jacob do you recall the issue with accessing the Serial Port through Node-Red on a Pi? I seem to remember there was an issue with this but do not recall the fix.
Ok, at that point I believe this would be a permissions issue of some sort. I would check the permissions of the /dev/tty.usbserial directory created when the USB modem is connected to the Pi.
I added the permissions then created a serial node. Some information seems to be passing. But the NCD nodes for gateway/device don’t seem to connect as well.
{“payload”:“\u0003�\n”,“port”:“/dev/ttyUSB0”,“_msgid”:“4fd6e41d31fcd690”}
But the values coming in seem pretty weird.
Can you export your flow from Node-Red and send it? You can export via the Menu in the top right (three horizontal lines) > Export > all flows > Download.
If Node-red isn’t working you can find the flow at ~/.node-red/flows.json
If you could include your package.json that may help as well. It can be found in ~/.node-red/package.json
This is the error code I’m getting. It looks like the port is running multiple services
[Error: Error Resource temporarily unavailable Cannot lock port]
19 Feb 11:36:07 - [red] Uncaught Exception:
19 Feb 11:36:07 - [error] TypeError: “path” is not defined:
nodered.service: Main process exited, code=exited, status=1/FAILURE
nodered.service: Failed with result ‘exit-code’.
nodered.service: Consumed 8.658s CPU time.
nodered.service: Scheduled restart job, restart counter is at 3.
Stopped nodered.service - Node-RED graphical event wiring tool.
Started nodered.service - Node-RED graphical event wiring tool.
19 Feb 11:36:29 - [info]
Welcome to Node-RED
19 Feb 11:36:29 - [info] Node-RED version: v3.1.4
19 Feb 11:36:29 - [info] Node.js version: v18.19.0
19 Feb 11:36:29 - [info] Linux 6.1.0-rpi8-rpi-v8 arm64 LE
19 Feb 11:36:30 - [info] Loading palette nodes
19 Feb 11:36:32 - [info] Settings file : /home/empiric/.node-red/settings.js
19 Feb 11:36:32 - [info] Context store : ‘default’ [module=memory]
19 Feb 11:36:32 - [info] User directory : /home/empiric/.node-red
19 Feb 11:36:32 - [warn] Projects disabled : editorTheme.projects.enabled=false
19 Feb 11:36:32 - [info] Flows file : /home/empiric/.node-red/empiric4_20ma.json
19 Feb 11:36:32 - [warn] Encrypted credentials not found
19 Feb 11:36:33 - [info] Server now running at http://127.0.0.1:1880/
19 Feb 11:36:33 - [info] Starting flows
19 Feb 11:36:33 - [info] Started flows
19 Feb 11:36:33 - [info] [serialconfig:48b81f5e359438a3] serial port /dev/ttyUSB0 opened at 115200 baud 8N1
19 Feb 11:36:33 - [warn] [csv:b0dd45f6c78b4f54] No columns template specified for object → CSV.
19 Feb 11:36:33 - [warn] [csv:5a6197a6c655822d] No columns template specified for object → CSV.
19 Feb 11:36:38 - [red] Uncaught Exception:
19 Feb 11:36:38 - [error] TypeError: “path” is not defined:
It looks like there was only one node in the export. You might have skipped the all flows which should be a tab on the export modal part of the export. By default it only exports the selected node.
It miraculously started working. I haven’t one anything except start stop node-red. I’ll have to figure out the process steps again on a fresh install.
Nothing has changed. Unless it was maybe because the device batteries died and so no data was passing through.
Restarting Node-Red can be helpful and is generally recommended after library installs to reset all memory.
I did notice on the last export that the only node was a serial port node from the 3rd part node-red serial port library set to USB0. Both that node and our nodes cannot consume that serial port so they may have been butting heads over it. Even if one was removed it may have been kept in memory to use it until a restart of node-red. The error code was a bit strange for this issue, but I have never tested it.
Let me know if you have any additional issues or questions.
