Wireless transmission of analog VDC
I’m looking for a solution to transmit the VDC output of a hall effect sensor used to monitor the level of a propane tank into a building less than 100ft away. Inside the building is a controller that can either interface with the receiver unit via RS485 ModbusRTU or by way of another analog input interface on the controller should there be an NCD product pair that just takes analogs on one side and outputs them on the other.
From what I’ve looked at, the 2-Channel 0-10V Receiver may be ideal for the remote sensor side of the link since it’ll be able to provide the +5VDC supply needed for the hall effect sensor, but I’m unsure what the best option would be for the side interfacing with my controller.
