Wireless Temperature Sensor Pinout
I have a K-Type Thermocouple sensor that I would like to wirelessly transmit back to our NCD gateway. I would like to use the Wireless Thermocouple Temp Sensor to accomplish this.
I was thinking that I could buy one of the M12 connectors and wire our sensor directly into the module instead of using the thermocouple connector. Does anyone have the actual pinout for this connector?
I am also open to an alternative if there is a better way to accomplish this.
Thank you!
M12 is 8pin
1 – TC1+
2 – TC1-
3 – TC2+
4 – TC2-
5 – TC3+
6 – TC3-
Thank you, @Bhaskar
Can you confirm that the linked M12 Connector will work with the linked Wireless Thermocouple Sensor?
no this won’t. This is a 5-pin… You will need an 8-pin…
hack – you can add this in your ocart and in order notes mention this " ship M12 8P instead of 5P"
