I tried to use encryption for my wireless vibration sensor. Sadly, it appears that I did something wrong. After activating the encryption between the router and the sensor, the stopped to communicate together. I guess that I failed to configure the router and the sensor with the same encryption settings.
I read somewhere on this forum that the only thing to do to solve this problem is the factory reset of the sensor. That’s what I did. I hit the reset button then I hold the config button for 20 seconds. The documentation says that this should put the sensor in configuration mode. But this didn’t work for me.
I used the labview ‘vibration tester’ utility to set the sensor in configuration mode. Sadly, the router seems to be unable to communicate with the sensor. I tries both PanID 7FFF and 7ABC (the config PanID)
I really dont know what I could to solve this problem
Do you have any idea ?
