Regarding the following product: I2C Converter with Dual Serial to 8-Port Hardware I2C - store.ncd.io
We plan on providing power to the board through the screw terminals. What range of voltage can we input to those terminals, and what is the maximum current draw we can expect?
Maximum current draw will be around 150-200mA. Input voltage range is 9-14.5VDC.
Thank you Travis! We are also using the Fusion Channel SSRC for this project. What is the range of wire sizes (AWG) that we can fit into the screw terminals?
They accept up to 12 ga wire.
