I would prefer to use the molex connector for the GPIO - can you tell me what part number I need to interface with it? Or provide a cable I can use instead?
If we can’t get the Molex connector could you tell us what connector is on the actual board circled in red? I believe these are the dual 8-channel GPIO’s, which is what I need. If I knew those connectors, perhaps I could figure out which molex connector I need to use. I can’t use this expansion cable 6 Inch (152mm) UXP Expansion Cable - store.ncd.io because it is a ribbon cable and I need to feed each of the 8 GPIO channels to a different location.
