Hi There,
I am trying to change the button background colors according to the relay state
On = Green
Off = Red
I would also like to change the color of the text to either color when the relay is in that state. I figure this is an OnClick function based on RelayState but I am unsure of where to place this in the code.
function build_button(text, onclick, classes = "button", id = ""){
return '<button onclick="'+onclick+'" classes="'+classes+'" id="'+id+'">'+text+'</button>';
function remove_superfluous_response(response){
response = response.replace('webiControl_Callback({"webiControlRespond":"', '');
response = response.replace(':",});', "");
return response;
function get_first_callback(kwargs){
if(kwargs.hasOwnProperty('callbacks') && kwargs.callbacks.length){
return kwargs.callbacks.shift();
else{
return false;
function get_turn_on_relay_command(relay_number){
return wrap_api([254, 48, (relay_number-1), 0]);
function turn_on_relay(relay_number, kwargs = {'callbacks': []}){
var cmd = get_turn_on_relay_command(relay_number);
var bank = Math.floor((relay_number-1+8)/8);
kwargs.bank = bank;
send_command(cmd, kwargs);
function get_turn_off_relay_command(relay_number){
return wrap_api([254, 47, (relay_number-1), 0]);
function turn_off_relay(relay_number, kwargs = {'callbacks': []}){
var cmd = get_turn_off_relay_command(relay_number);
kwargs.bank = bank;
function get_set_relay_timer_command(timer, hours, minutes, seconds, relay_number){
// timer ids start at 50 for standard timers, 70 for pulse timers, timers are shared.
timer = timer + 49;
relay_number = relay_number - 1;
return wrap_api([254,50, timer, hours, minutes, seconds, relay_number]);
function set_relay_timer(timer, hours, minutes, seconds, relay_number, kwargs = {'callbacks': []}){
var cmd = get_set_bank_status_command(timer, hours, minutes, seconds, relay_number);
function get_set_relay_pulse_timer_command(timer, hours, minutes, seconds, relay_number){
timer = timer + 69;
function set_relay_pulse_timer(timer, hours, minutes, seconds, relay_number, kwargs = {'callbacks': []}){
function get_set_bank_status_command(relay_binary, bank){
return wrap_api([254,140, relay_binary, bank]);
function set_relay_bank_status_command(relay_binary, bank, kwargs = {'callbacks': []}){
var cmd = get_set_bank_status_command(relay_binary, bank);
kwargs.bank = bank;
function get_toggle_relay_command(relay_number){
return wrap_api([254,47, (relay_number-1), 0, 1]);
function toggle_relay(relay_number, kwargs = {'callbacks': []}){
var cmd = get_toggle_relay_command(relay_number);
kwargs.bank = bank;
function wrap_api(cmd){
var header = 170;
var length = cmd.length;
var cmd_sum = cmd.reduce((a,b) => a+b, 0);
var checksum = (header+length+cmd_sum) & 255;
return [header, length].concat(cmd).concat(checksum);
function get_all_adc_values_10bit_command(){
return wrap_api([254,167]);
function get_all_adc_values_10bit(kwargs = {}){
var cmd = get_all_adc_values_10bit_command();
function get_all_adc_values_8bit_command(){
return wrap_api([254,166]);
function get_all_adc_values_8bit(kwargs = {}){
var cmd = get_all_adc_values_8bit_command();
function get_single_adc_values_8bit_command(input){
var input_byte = 149 + input;
return wrap_api([254,input_byte]);
function get_single_adc_values_8bit(input, kwargs = {}){
var cmd = get_single_adc_values_8bit_command(input);
function get_single_adc_values_10bit_command(input){
var input_byte = 157 + input;
function get_single_adc_values_10bit(input, kwargs = {}){
var cmd = get_single_adc_values_10bit_command();
function get_relay_bank_status_command(bank){
var cmd = [254, 124, bank];
cmd = wrap_api(cmd);
return cmd;
function query_relay_bank_status(bank, kwargs = {'callbacks': []}){
// callback = get_first_callback(kwargs);
if(!kwargs.hasOwnProperty('bank')){
kwargs.bank = bank;
var cmd = get_relay_bank_status_command(kwargs.bank);
function update_adc_UI(event, kwargs = {}){
event = remove_superfluous_response(event);
var adc_values = event.split(',').slice(2, event.length-1);
var items = [].slice.call(document.querySelectorAll("[data-adc-channel]"));
items.forEach((item, i) => {
item.querySelectorAll('.adc_value')[0].innerHTML = adc_values[i];
var bar_div = '<div style="width: '+(adc_values[i]/255*100)+'%"></div>';
item.querySelectorAll('.adc_bar')[0].innerHTML = bar_div;
function macros_display_response(event, kwargs = {}){
document.getElementById('default_macros_response_target').innerHTML = event;
function get_macros_ui_json(){
return {
'buttons': {
0: {
'label': 'Custom Button 1',
'callbacks': [
macros_display_response.name
'commands': [
get_turn_on_relay_command(1),
get_turn_off_relay_command(1),
get_all_adc_values_8bit_command(),
get_set_relay_pulse_timer_command(1, 0, 0, 5, 1),
get_set_relay_timer_command(2,0,0,5,2),
get_single_adc_values_10bit_command(1),
get_single_adc_values_8bit_command(1),
get_all_adc_values_10bit_command(),
// timer, hours, minutes, seconds, relay_number
1: {
'label': 'Custom Button 2',
'callbacks': [
'commands': [
get_turn_on_relay_command(2),
get_turn_off_relay_command(2),
function build_macros_UI(){
var macros_JSON = get_macros_ui_json();
var macros_html_string = '<div class="macros_wrapper test">';
for(var button in macros_JSON.buttons){
var onclick_array = [];
for(var command in macros_JSON.buttons[button].commands){
onclick_array.push(macros_JSON.buttons[button].commands[command]);
// onclick_string += JSON.stringify(macros_JSON.buttons[button].commands[command]);
var callback_array = []
for(var callback in macros_JSON.buttons.callbacks){
var onclick_string = 'onclick="send_mutliple_commands('+JSON.stringify(onclick_array)+', {\'callbacks\': ['+macros_JSON.buttons[button].callbacks+']})"';
macros_html_string += '<button class="button" '+onclick_string+'>'+macros_JSON.buttons[button].label+'</button>';
macros_html_string += '</div>';
document.getElementById('tbc_05').innerHTML += macros_html_string;
function get_standard_ui_json(){
return {
'number_of_relays': 4,
'names': [
'MINER 1',
'MINER 2',
'MINER 3',
'MINER 4',
'buttons': {
'turn_on_relay': 'On',
'turn_off_relay': 'Off',
'toggle_relay': 'Toggle',
function build_UI(){
var standardJSON = get_standard_ui_json();
var ui_html = '<div class="bank_wrapper"><div class="bank_header"><span>Bank 1</span><button class="button" onclick="query_relay_bank_status(1, {\'callbacks\': [update_relay_bank_status_ui]})">Refresh</button></div>';
if(standardJSON.hasOwnProperty('number_of_relays')){
var i = 1;
var bank_check = 1;
while(i <= standardJSON.number_of_relays){
if(standardJSON.hasOwnProperty('names') && i <= standardJSON.names.length && standardJSON.names[(i-1)] !== false){
var current_bank = Math.floor((i-1+8)/8);
if(current_bank != bank_check){
ui_html += '</div><div class="bank_wrapper"><div class="bank_header"><span>Bank '+current_bank+'</span><button class="button" onclick="query_relay_bank_status('+current_bank+', {\'callbacks\': [update_relay_bank_status_ui]})">Refresh</button></div>';
ui_html += '<div class="relay_wrapper" data-relay="'+(i-((current_bank-1)*8))+'" data-bank="'+current_bank+'">';
// check if names are defined. Check if there are more relays than names.
if(standardJSON.hasOwnProperty('names') && i <= standardJSON.names.length){
ui_html += '<div class="relay_label">'+standardJSON.names[(i-1)]+'</div>';
else{
ui_html += '<div class="relay_label">Relay '+i+'</div>';
ui_html += '<div class="relay_status">Querying</div>';
if(standardJSON.hasOwnProperty('buttons')) {
for(var button in standardJSON.buttons){
ui_html += '<div class="button"><button onclick="'+button+'('+i+', {\'callbacks\': [query_relay_bank_status, update_relay_bank_status_ui]})">'+standardJSON.buttons[button]+'</button></div>';
ui_html += '</div>';
var bank_check = current_bank;
i++;
i=1;
while(i<=current_bank){
query_relay_bank_status(i, {'callbacks': [update_relay_bank_status_ui], 'bank' : i});
i++;
ui_html += '<button onclick="set_relay_bank_status_command(255, 0);query_relay_bank_status(1, {\'callbacks\': [update_relay_bank_status_ui]});query_relay_bank_status(2, {\'callbacks\': [update_relay_bank_status_ui]});query_relay_bank_status(3, {\'callbacks\': [update_relay_bank_status_ui]})")>Turn On All Relays</button>';
ui_html += '<button onclick="set_relay_bank_status_command(0, 0);query_relay_bank_status(1, {\'callbacks\': [update_relay_bank_status_ui]});query_relay_bank_status(2, {\'callbacks\': [update_relay_bank_status_ui]});query_relay_bank_status(3, {\'callbacks\': [update_relay_bank_status_ui]});">Turn Off All Relays</button>';
document.getElementById('tbc_04').innerHTML = ui_html;
function send_command(cmd, kwargs = {}) {
var web_i_cgi;
cmd = cmd.join(',');
var callback = get_first_callback(kwargs);
setTimeout(function () { web_i_cgi = new NCD_AJAX( 'webi_control.cgi', callback, kwargs); web_i_cgi.doPost(cmd);}, 300)
function send_mutliple_commands(cmd, kwargs = {}){
var web_i_cgi;
cmd.forEach((item, i) => {
cmd[i] = cmd[i].join(',');
cmd = cmd.join(':');
function toHexString(byteArray) {
return Array.from(byteArray, function(byte) {
return ('0' + (byte & 0xFF).toString(16)).slice(-2);
}).join(' ')
function check_packet_api(packet){
var responses = packet.split(':');
// console.log(responses);
responses.forEach(function(response){
var response = response.split(',');
console.log('received bytes: (dec)[' + response.join(', ') + '] (hex)['+toHexString(response)+']');
var response_checksum = response[response.length-1];
var expected_checksum = response.reduce((a,b) => parseInt(a)+parseInt(b), 0)-response[response.length-1];
if(response[0] != 170){
// console.log('Response header was not 170');
console.log('Response header was not 170, packet may be invalid');
// return false;
if(response_checksum != expected_checksum){
console.log('Checksum: ' + String(response_checksum) + ' is incorrect. Expected checksum of: ' + String(expected_checksum));
if(response[1] != response.length-3){
console.log('Payload length error. Expected ' + String(response[1]) + ' bytes, received payload of ' + String(response.length-3) + ' bytes.');
// function wrap_api(cmd){
// header = 170;
// length = cmd.length;
// cmd_sum = cmd.reduce((a,b) => a+b, 0);
// checksum = (header+length+cmd_sum) & 255;
// return [header, length].concat(cmd).concat(checksum);
function update_relay_bank_status_ui(event, kwargs = {}){
if(kwargs.hasOwnProperty('bank')){
check_packet_api(event);
var status = event.split(',')[2];
var bank_elements = document.querySelectorAll("[data-bank='"+kwargs.bank+"']");
bank_elements.forEach(function(item){
if(status & 1<<(item.dataset.relay-1)){
item.getElementsByClassName('relay_status')[0].innerHTML = "On";
}else{
item.getElementsByClassName('relay_status')[0].innerHTML = "Off";
function check_interval_triggers(link){
if(link.id == 'tb_6' && adc_poll == undefined){
var adc_poll = setInterval(function(){get_all_adc_values_8bit({'callbacks': [update_adc_UI]})}, 2000);
else if(link.id != 'tb_6' && adc_poll != undefined){
clearInterval(adc_poll);
var adc_poll = undefined;
document.addEventListener("DOMContentLoaded", function(){
build_UI();
build_macros_UI();
[].slice.call(document.getElementById('nav').children).forEach(item => item.addEventListener('click', function (){ check_interval_triggers(item) }));
</script>
</head>
