We have a IOADR810 relay board in on of our testers that needs a replacement. I couldn’t find that model on the website currently. What can we do for a replacement and/of does documentation still exist for the model?
Eric
Eric
Hi Eric,
That’s a pretty old relay controller. At least 10+ years.
We no longer carry IOADR810 on the online store. However you may be able to replace it with this controller:
This may require some changes to the software that operates the board. Also please confirm that the 8 relays and 8 A/D inputs on this substitute device replicate all functionality currently used on your IOADR810 board.
I unfortunately no longer have access to the documentation for that board.
Thank you Eric,
Hey Travis,
Thanks for the response.
I think our application needs a 8-DPDT relay board with two 8-bit IO digital ports.
The one you recommended has analog ports.
Do you have an existing board with digital IO ports?
Eric
Hi Eric,
This board has 8 DPDT relays and 8 ADCs which can be used to monitor digital IO signals:
Thank you Eric,
