Vibration sensor and gateway compatibility
Is the standalone vibration sensor (PR55-67A) compatible with the Azure micro gateway (PR55-21_AZURE)?
Many thanks
Hi @charlesg Sure, for the Smart Industrial IoT Wireless Vibration Temperature Sensor, we recommend using the Enterprise IIoT Gateway, which comes with nodered and the NCD library pre-installed and ready to use.
Additionally, there are third-party nodered libraries for Azure that you can import into your nodered instance to send sensor data to Azure seamlessly.
Eduardo M.
Thanks Eduardo, but to confirm, does it work with this one specifically?
Azure Gateway - Wi-Fi Micro Gateway for Microsoft® Azure® - NCD Store
Hi @charlesg Unfortunately, no, it won’t work with the Azure Gateway.
Eduardo M.
