I have got my ncd V3 vibration sensor plus and Industrial computing edge gateway interfaced like the below image:
However, as I plug the sensor onto a running motor for vibration signatures. I am not able to receive any data. I keep on receiving debug messages approximately every 30 seconds from the debug node “debug1” which is connected to the gateway. What could be the problem with the sensor debug node? Why can’t my sensor provide me with data ???
See the picture below of what I mean:
I also noticed as I turned off my motor where the vibration sensor was attached to it, I got this message as the image below:
I have tried many strategies but nothing seems to be working. I also noticed on Node-Red’s manage palette @ncd-io/node-red-enterprise-sensors request for an update to 0.1.15. However, I am getting an error message when I try to update.
2024-02-11T08:13:12.321Z Install : @ncd-io/node-red-enterprise-sensors 0.1.15
2022-12-22T12:48:54.750Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict @ncd-io/node-red-enterprise-sensors@0.1.15
2022-12-22T12:48:56.168Z [err] npm
2022-12-22T12:48:56.169Z [err]
2022-12-22T12:48:56.170Z [err] WARN config production Use --omit=dev instead.
2022-12-22T12:50:07.928Z [err] npm
2022-12-22T12:50:07.928Z [err] ERR!
2022-12-22T12:50:07.929Z [err] code
2022-12-22T12:50:07.929Z [err] CERT_NOT_YET_VALID
2022-12-22T12:50:07.930Z [err] npm
2022-12-22T12:50:07.930Z [err] ERR! errno CERT_NOT_YET_VALID
2022-12-22T12:50:07.938Z [err] npm
2022-12-22T12:50:07.938Z [err] ERR!
2022-12-22T12:50:07.939Z [err] request to https://registry.npmjs.org/@ncd-io%2Fnode-red-enterprise-sensors failed, reason: certificate is not yet valid
2022-12-22T12:50:07.946Z [err]
2022-12-22T12:50:07.947Z [err] npm
2022-12-22T12:50:07.947Z [err] ERR! A complete log of this run can be found in:
2022-12-22T12:50:07.947Z [err] npm ERR! /home/ncdio/.npm/_logs/2022-12-22T12_48_56_052Z-debug-0.log
2022-12-22T12:50:07.966Z rc=1
Please advise what should I do about these issues.
