I am trying to replace a manual switch in the field to open and close a different manufactures controller.
I would be using this relay as a dry contact that will switch 12 VAC.
I have need for some high power relays in a related application and wondered if these would also work for the application above.
One of the blurbs about this specific relay says “this relay should never be used for low-power signals”, but I’m not quite sure what that means.
