Using the 0-10V DAC I2C with Home Assistant OS GPIO
Hi
Was wondering if I could use product:
https://store.ncd.io/product/1-channel-0-10v-dac-digital-analog-converter-i²c/
With Home Assistant OS via a RPi GPIO pins?
thanks
Yes, you can use that board with a Raspberry Pi. You will need an I2C interface adapter shield to connect it to the Pi:
