I’d like to use a mini module from the nodeLink listing: ISL29125 Digital Red Green Blue Color Light Sensor with IR Blocking Filter I2C Mini Module. Ideally I would utilize it with the IoT micro gateway(MQTT).
Is there an enclosure and configuration that someone can recommend to accomplish this?
Or do I have to set this up with RasPi/Arduino and handle the gathering/transport of the readings separately?
