ncd.io Enterprise Wireless Vibration and Temperature Sensor with Time series.exe
I downloaded this file from the ncd.io website. The error message says it requires version 2017 (or compatible) so I installed the 2017 SP1 LabVIEW Run-Time Engine but it still says the runtime is not installed. What else do I need to do to run these files?
Thanks. That’s what it was. The files apparently are specific to both version and bitness. I have one file that would only work with 32-bit version 2019 and another that would only work with 32-bit version 2017. I had installed the 64-bit versions so none of the files would work.
