I am trying to install OPCUA(node-red-contrib-opcua) and SQLSERVER (node-red-contrib-mssql-plus) pallets on LTE Cellular Ethernet WiFi IoT Edge Computer.
. But the installation is unsuccessful.
I tried both from UI and also from the command line.
One other thing you can try is updating Node-Red to the latest version supported. You can do that by opening the terminal to the IoT Edge Computer then enter the following commands:
opkg update
opkg upgrade onion-node-red
After that reboot the IoT Edge Computer and attempt installing the library again. If that does not work then you will need to upgrade to the Enterprise IIoT Gateway.
