I have reloaded the recovery router configuration files into the zigmo router, and reset the thermocouple to default configurations multiple times. However im still unable to get any data that is sent when using xctu and alpha station 1.0.0.8
I am using new sets of energizer batteries to power the sensor and set the jumper to the PS pins. I assume that it is powered up, it is impossible to tell without any indicator though.
I have checked the configuration settings for the zigmo in xctu and alpha station, both are saying the network id is 0x7FFF
I have connected both devices with the accompanying 900mhz antenna.
And have placed both devices more than 3 feet away from each other. When i use xctu to scan the network, the thermocouple is not detected.
I am using alpha station 1.0.0.8, and did as you suggested, and am not getting any broadcast messages from the sensor.
My zigmo is connected to the computer as COM7, and baud rate is 115200. I have tried switching USB ports on the same machine and still the same issue. I have tried pressing the reset button and waiting for a response on alpha station and also tried pressing reset and then holding configure for more than 15seconds, and still the same issue. Im not getting any response on alpha station.
