I have an Electron connected to the PR35-17 IC2 battery only shield.
It works perfectly as i want, but i would like to turn off the boost circuit, so that it isn’t drawing unnecessary power, when unused (in sleep mode).
I believe I read (before it was taken away) that you could cut the boost circuit power, by setting the A3 pin to low on the electron. I can even see the connection to the boost circuit on the board.
But when I set the A3 pin to LOW, nothing happens. It still flows 5V out the I2C power pin.
I’ve checked with my multimeter, that the power on A3 is in fact cut, and it is.
The A3 does shut down the boost circuit but when the boost circuit is off it bypasses the input voltage to the i2c port. We were not aware of this when we designed the product( this is the reason we took it away).
We can issue a refund If you want.
@Anil_Bhaskar Is it possible to get the PCB drawing of the PR35-17, you know the components and all (perhaps even in EAGLE format?)
I want to make it part of a bigger board with other things I need for my Particle device. And if I get it to work as intended, I can send the schematics.
What are the features of this prototype?
If we skip the refund on the PR35-27, could I receive one of those early prototypes without the hassle of getting money involved?
