I have a NCD IIoT Gateway and I want to use this add on but apparently nodeJS isn’t up to snuff on here. I looked for an upgrade path but couldn’t find it in an obvious place. Any help would be amazing!
Hi @jmelcher Sure, we have an article that explains how to update Node.js and Node-RED on the Enterprise IIoT Gateway:
Please take a look at this.
Eduardo M.
@Eduardo_Mtz I believe @jmelcher has the previous generation Gateway here:
@jmelcher can you confirm if this is the gateway you have? If so it is not upgradable to later versions of NodeJS due to processor limitations. We would recommend upgrading to the Enterprise Gateway here which supports modern versions of NodeJS:
Travis
The one I have is below!
Ok. I recommend following Eduardo’s instructions in that case.
This worked great! Thank you!
Great! @jmelcher Feel free to start a new thread if you have any questions.
Eduardo M.
