Summary:
I am trying to troubleshoot a 0-5VDC signal from a pressure transducer wired to a UAD1216 expansion board. Everything looks like it is wired correctly and I can confirm a voltage output from the sensor, but Base Station shows all channels as reading 5V.
Setup
ZUXPSR32xDPDTPROXR with an UAD1216 connected to the UXP port. 12VDC supply connected through barrel connector on the board.
3-Wire pressure sensor with 0-5VDC signal.
a. Excitation+ wired to “+” on 12VDC terminal strip on the Relay Board.
b. Excitation - wired to “-” on 12VDC terminal strip on the Relay Board.
c. Signal wired to UAD1216 Channel 0 terminal B. -
Both up/down jumpers on the UAD1216 are in the DOWN position.
Device jumper on the UAD1216 is in the “0” position.
Results
Pressure sensor is outputting 1.6V on signal wire.
Using Base Station software to monitor the UAD1216 with “UXP AD1216 Analog to Digital Conversion Command Set” screen.
“Monitor Device 0” is checked.
Clicking “Read 8-Bit 1-Channel at a Time” returns all 16 channels with “255 5V”
Clicking “Read 12-Bit 1-Channel at a Time” returns all 16 channels with “4056 5V”
Moving the “8-15” jumper to the UP position gives the same results.
Conclusions/Questions
It’s possible the wiring incorrect. From the description above can you confirm if the wiring is right? Is there a manual that shows wiring examples rather than a photo with captions?
It’s possible the main relay board isn’t communicating with the UAD1216. Is there a way to determine this with Base Station or some other software?
I know this is long, but I am trying to provide as much detail as possible to resolve this quickly. I have already combed the website without much success. If there is something I have missed, please direct me to the appropriate resource.
Please let me know if you need any other information as well as your thoughts.
Thank you.
