System configuration using PR60-21 with both XR and UXP ports
When you say make changes do you mean send commands to control the board or are you making configuration changes on the board through the Device Configuration panel?
Do you have the ADC board still connected to the DPOT board? If so can you disconnect it and also disconnect USB so that the only connection is to the DPOT board over WiFi?
What ICs were replaced on the DPOT board?
