Hello, I’m wondering if it is possible to drive 12VDC latching solenoids and relays with your controllers. These would be single coil with current latching it closed in 1 direction and then unlatching it when reversed.
Thank-you
Thank-you
Hi Tyler,
We recommend following controller for controlling solenoids
https://store.ncd.io/product/mcp23008-8-channel-8w-12v-fet-solenoid-driver-valve-controller-with-i2c-interface/
Is there anything I would need in addition to drive a single coil latching solenoid? This is for a remote solar application so I need to be able to drive latching relays and solenoids to save on power.
