In smart mode the relay should turn off after a period of time. I cannot honestly remember the delay but if you disconnect the mating board you should see the relay on the receiver turn off eventually. Let me know if that is not happening.
Hi Kareem1977,
We don’t have smart mode function on the newer lantronix Module due to limited memory. The jumper is for static IP Address.
I will check the webpage to make sure the description is correct.
Shirui Xu
