Smart Industrial IoT Wireless Vibration Temperature Sensor RAW DATA
Dear All,
We need to get raw data from the sensor in object.
For our application NODE-RED has not the right performance.
Usually we use Python or NODE-JS.
Is it available a library (software) for this need?
In case, do you ave a suggestion for reaching raw data?
Thanks and Regards,
Claudio
Hi Claudio,
Our Node-Red library(written in NodeJS) is open source and available here:
You would be specifically looking at the Type 80 for single channel wired probe vibration sensor, Type 81 for two channel wired probe vibration sensor, or type 84 for the stand alone vibration sensor.
Please let us know if you have any questions.
Thank you.
Really we need Type 40
The sensor you have is type 84.
Yes, but the sensor’s description shows clearly that it is possible to get raw data in the time domine. Please see attachment.
Please give me the instruction in detail for that
Yes, you can get raw data from it.
set the data mode to raw mode and set destination address to your gateway address.
Please, could you send me the command for setting the sensor in mode on-demand?
Hi @hydrapred Sure, to enable on demand time domain data send this command:
7E 00 15 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 F4 4F 00 00 54 09 02 51
Command – F4 4F 00 00 54 09 02
F4 – Command header
4F – Sub command
00 – Node id
00, 54 – Sensor type (Type 84 in DEC)
02 – Enable on command time domain data
Eduardo M.
