We are set to begin work on a project which involves some of NCD’s hardware. We wanted to give NCD an overview of the design to have expertise confirmation that our objectives are reasonable. We intend to implement the following:
Use Visual Studio similar to NCD Alpha Station software on an existing PC. Our application will need the provided NCD drivers to create a custom UI built in C# and WPF.
Use the USB-Wifi modem (SKU PR55-17A) for communication with IoT devices.
Add a IoT Long Range Wireless Multi Channel Dry Contact Closure Transmitter (SKU PR52-18_CC) in an existing enclosure which will be approximately 300’
from the the wireless modem. We would also like to power this device from a 24VDC power supply.
Add a Wireless 4-Channel IoT Relay Controller 10-Amp endNode (SKU ASM1-3) in an existing enclosure which will be approximately 500’ from the wireless
As far as functionality, is the chosen hardware and software reasonable.
