Simultaneous Vibration Signal Acquisition from two Sensors, using Mega Modem
I would like to ask if you have experience or technical guidance on acquiring vibration signal from two sensors simultaneously using a single Mega Modem. I am interested in understanding bandwidth limitations, as well as how the data synchronization is managed.
Regards
Giacomo
mega mode modes not work with vibration sensor.
You can set the RTC clock using node red and set node id 0 of one sensor and node id 3 of the other one.
both will sample at same time
