I’d appreciate an explanation on how to set up the baud rate of the I2C interface, in a PR49-35 card.
I’ve down loaded the NCD Base app, and am able to perfectly control the card via AnyI2C app.
thanks
Kobi
@ryan1 Can you explain how the I2C clock speed can be set on Fusion based I2C devices? I’m not able to find the EEPROM register for this setting in documentation. I believe default is 100K but not sure how to lower it.
