I realize this is new and still in beta, but I was hoping to get information to setup a static IP in the Atrium Gateway. I see that the dashboard is now running through node red as opposed to the Robustel OS in the previous versions, but this seems to really limit the capabilities available on these gateways. Is it possible to still access the Robustel OS or something similar to setup things like GRE tunneling, VLANs, etc?
Hi Ryan, Sure, you should be able to access to the Web Configuration Interface (robustel) on this Atrium Gateway version. In this version it can be accessed using the url:
http://ncd-[last_4_of_mac].local:8080
Where [last_4_of_mac] is the last 4 characters in the mac address printed on the side of the gateway without the colon. i.e. http://ncd-c398.local:8080
Try this and share your results.
Eduardo M.
Thanks Eduardo, that worked perfectly!
