I need help to control the ProXR relays over direct serial connection.
my goal is to write a C# class to control the relay, the class that send direct command over serial exists and i can use the NCD software to control them, but how can i control them directly ?
This is exectly what i nedded thanks !!! but can i use it without winform ?
im missing these methods without winform:
ncd1.SettingPort()
ncd1.OpenPort()
To be completely honest I do not program in C# and this was developed by a couple other engineers here. I will CC them in and see if they can assist with that.
It is possible. You can create NCDComponent from the code directly. Please refer the sample of serial port from Microsoft. NCDComponent is similar with serialport object. Or you can use serial port directly.
Shirui Xu
