I’m looking to monitor 3 phase energy supplies to a set of factory machine tools. I see you have a ‘3 Channel Industrial IoT Wireless AC Current Monitor Sensor’ and it states on your website page for this item ’ * AC Current Range 0-100A RMS Measurement’. Is this a measurement capacity per Phase (Channel?) as I am looking to use this device in the UK. In addition, if the input cable to the machine tool was 3 phase, but within a 3 phase multi-core cbale, would I need to split the cable to install this sensor?
Yes, that 100 amp current rating is per CT(x3).
Yes, you will need to split the cable so each CT clamps around only one phase.
Is it possible to get a ‘3 Channel Industrial IoT Wireless AC Current Monitor Sensor’ tat connects directly to Wifi and an MQTT broker? Also is it possible to get it with a Power Adapter rather than batteries? Finally, what is the fastest data collection rate that this sensor can support in m/s. Thanks
