Sampling time interval, transmission power and repeater
I am new to NCD and Node-RED, and I have a few questions. I’ve recently purchased two Smart Industrial IoT Wireless Vibration Temperature Sensors (PR55-67A) and two Industrial IoT Wireless to USB Modems (PR55-17A) (Order #555563) for testing.
My questions are:
  1. How can I set the sampling time interval to 1 minute? I attempted to set the Delay to 60 seconds, but it did not work. (Still 5 minutes)
  2. How can I increase the transmission power of the sensor and receiver? Is this done through settings or by replacing with even higher-power antennas?
  3. How do I set up a repeater using the USB modem? How do i know that the repeater is functioning correctly?
  4. What do the on_request_timeout and lifetime_transmissions mean?
Thank you for your assistance in advance!
Best regards,
Howard
the minimum interval is 5 min.
the power is set to max by default
Just power on the usb and it will start acting as repeater.
the number of messages device has sent since its inspection
Thank you very much, Bhaskar.
