I want to build a listener that will continuously read signal from Wireless Ethernet Modem. Think of it the module that is feeding data to Alpha Station. After I read the data, I will process for some AI module.
Is there some sample or starting code available for such listener for Windows 10 machine? Any programming language will work.
Most people use Node-Red to read the data from the sensors. We have a library that gives a drag and drop node for data ingestion. Once you get the data you can use Node-Red to send it to other services/servers through TCP, UDP, HTTP, MQTT, or almost anything built on top of those protocols.
