I’m having trouble sending commands to this particular relay. I have stumbled upon this library: GitHub - ncd-io/Industrial-Relay-Control
After following the examples I produced the code below:
import serial
import ncd_industrial_relay
if name == ‘main’:
serial_port = serial.Serial(’/dev/ttyS0’, baudrate=9600, bytesize=8, stopbits=1, timeout=.5)
board1 = ncd_industrial_relay.Relay_Controller(serial_port)
print board1.turn_on_relay_by_index(1)
serial_port.close()
however when run i get the following error messages:
File “test.py”, line 8, in
File “/home/asdf/ncd_industrial_relay.py”, line 25, in turn_on_relay_by_index
return self.process_control_command_return(self.send_command(command, 4))
File “/home/asdf/ncd_industrial_relay.py”, line 149, in send_command
self.combus.write(command)
File “/usr/lib/python2.7/dist-packages/serial/serialposix.py”, line 475, in write
n = os.write(self.fd, d)
TypeError: must be string or buffer, not list
Have I correctly implemented the example? Is this the correct library to use? Can someone point me in the direction of an example with python?
below is the specific product I am using
