I’m looking for a way to monitor 2 remote voltage sources, and ideally 4 remote triggered relays, for DC voltage up to 60v. Found this website by my search for this, and it seems that the Fusion Relay may have a solution to solve this, but confused by the overall amount of modules available.
I’d like to be able to go to a local IP address in a web browser, and monitor the remote voltage and trigger the remote relays, across a local IP network.
Unfortunately we don’t have an out of the box solution for this.
Its possible to do this using an after-market sensor connected to one of the ADC inputs on a Fusion Expansion board. I wouldn’t be able to point you at the appropriate sensors though. The voltage monitoring on the Fusion is for 0-5V sensors.
