I’m wanting to programmatically create my events… is there a reference for the codes the scheduling software uses?
Speaking of this:
4SAJAQEBAAAAAAAAAAAAAA==
That represents 12:00 AM relay … on I think.
I’d like to be able to generate this. The scheduling software is kind of difficult to work with if there’s problems, which is why I was hoping to be able to make the events some other way.
Taralist is designed and produced by us. That’s what the developer told me when I asked. I have talked to him about porting it before and it is apparently a fairly complicated process to burn events due to the nature of basically mimicking Cron jobs on a microprocessor.
The best I can do for this is to give you the source code to Base Station which handles the Base Station implementation. Its a huge program though so it will probably be difficult to isolate the Taralist portion.
