I’ve recently bought the below sensor and azure connected wireless hub. I want to be able to to look at the raw data. The output from the sensor appears to only be the rms of x,y & z axes and also the max values of those axes too.
Does anyone know how to obtain any raw data to form a FFT of freq and amplitude?
Currently the Azure gateway does not support Raw Data from the vibration sensors. We recommend the IoT Edge Computer here for that which can send this data to Azure using Node-Red:
@Bhaskar can you confirm/deny that the Predictive Maintenance sensor support Raw Data and whether or not it supports raw Data on request?
