All our I2C shield come with 4.7K pull ups enabled including the PR2-2.
I am attaching the sch.
I just ran one quick test over here and did this
Connected the shield to a 5V supply ( shield is not plugged in the pi) and measured voltage at SCL and SDA lines and the lines are pulled up to 3.3V.
we have sold thousands of these and never had any issue with pi. If you can explain more about the issue we can run some more tests.
I did more digging into it. I am using PR2-2.
My test input power supply was around 4.4V or so and it was producing 3.3V. Once i noticed that, i changed the supply to 5V and the voltage started to go close to around 3.6V or so. The root cause was the level shifter.
We changed the Vref2 voltage ( level shifter) on the board and then the I2C voltage went back to 3.3V.
Once we get your boards we will get these fixed and will ship back next day.
