I really need help with this ASAP. I correctly connected my One Channel 0-10V DAC I2C Digital To Analog Converter to my raspberry pi 3B+. Even though the converter indicates that it has power (led is on), the raspberry py does not detect the board. When I asked the raspberry pi for the connected IC2 devices, it tells me that none IC2 is connected. The IC2 communication on my pi is enabled.
HELP! Does the board only work if I get Raspberry Pi I²C Interface Adapter? Why can’t I just directly connect the converter to the raspberry pins?
