I need to identify the 6 pin connector used on the R2x Relay to replace a damaged one.
That drawing is awful, but I don’t have great image editing software. You can barely see it, but there’s a red box towards the top right of the board.
Yes I need the connector that mates with those pins
That appears to be an after-market connector. The only product we have that will connect to those pins is the 6 Pin Quick Start Kit (https://store.ncd.io/product/12-volt-quick-start-kit-with-6-pin-flex-ribbon-connector/)
Thank you
Can you share the part number for the connector and sockets that are part of that kit. It may help me towards finding the connector I am trying to replace.
I’ll look into it and see what I can find.
The part on the Quick Start Kit that connects to the pins is this cable: https://www.digikey.com/product-detail/en/te-connectivity-amp-connectors/A9BAG-0606F/A9BAG-0606F-ND/161577
