Can the R15PL_KEYFOB be hard wired without using the plug?
What is amp draw on the board?
Thanks!
T. Laird
Thanks!
T. Laird
If you are referring to the power supply connection yes. There are 2 screw terminals on the board where 12VDC can be supplied to the board instead of using the 2.1mm barrel connector.
